Dylan Mckenzie
Hi I'm having a few problems with my indy 500 it's is not stock the motor is oversized .0010 compression is good on both sides it has a DG performance pipe and is clutched to match the pipe I was tuning it today because of the warmer weather (-0 c) it was running good it seemed to be running a little hot but there was no sine of it being lean so I went out and topped it out to see if it would lean out it didn't it but now the exhaust has gone from blueish to clear you can't see it at all the spark plugs are brown the gas is mixed 80 to 1 and it is supposed to be oil injected is it possible for it to fail? Any suggestions for problems?
