Pray4snow714
Sled seems slightly under powered, won’t rev past 6900rpm, and tops out at 85mph.Any help on what to check next would be greatly appreciated. Here is a list of things I have done and verified good.
-power valves cleaned, cable is not broken, electric motor does sweep/ move when sled is first started. Does anyone have instructions onto how to properly adjust the cable, I was thinking they may not be opening all the way?
- reeds look good
-125psi compression on both cylinders -both coils produce strong spark
- check engine light is not on
- on Non-ethanol mode & running good fuel
It doesn’t seem like a clutching issue, but I’m honestly no expert on that stuff.
This all started after replacing the motor. Almost feels like a limp mode.
Thanks in advance.
- reeds look good
Thanks in advance.
