Anyone Running Straightline NOS System
Discussion in 'Rush/Switchback' started by sschmitty32, Aug 20, 2018.
  1. sschmitty32
    sschmitty32 New Member
    11
    Racine,Wi
    5
    2017 Polaris Rush 800 Pro-S
    Curious if anyone has run or currently running Straightline’s NOS system? Any feed back would be great.
  3. jfaub63
    jfaub63 Member
    90
    il.
    42 years
    2015 Pro S 800
    I'm interested as well.
  4. Pockets
    Pockets New Member
    9
    Lloydminster, Alberta
    25
    2006 Polaris 600 RMK
    I installed one years ago on my 2006 600 RMK. Still have it on. Works great. The hardest part was finding the proper 1/8 to 1/16 plastic reducer fitting for the fuel line to feed the fuel nozzles. Acklands Grainger in the US was the only place, and had to order 10 or 20 of them at once. I plug the power and ground into an unused connector in the wiring harness by the steering hoop when I am going to use it. 400 rpm gain on the button, supposed to be a 40hp shot. Can have the throttle pinned at 70 mph, hit the button and the skis pop up instantly stay off the ground as long as you are on the button. The power is exactly the same until the bottle is empty. I have the bottle mounted upside down to my fender in front of the muffler, used a boondocker nitrous bottle bracket, bolted to the fender.
  5. Pro116
    Pro116 Moderator Staff Member Moderator
    245
    Shiocton,WI
    It use to be Holtzman and then Straightline bought out Holtman and there pantent. I have ran a few of there kits they work great.
  6. jfaub63
    jfaub63 Member
    90
    il.
    42 years
    2015 Pro S 800
    What kind of octane did you need to run on the 40shot?
  7. Pockets
    Pockets New Member
    9
    25
    I run pump gas 91 octane. Just adjust the fuel screw properly on the valve for the additional fuel.
    I can hold the button for a mile, until the DET starts to flash, then I let go of the button. Can keep the throttle pinned the entire time.
    When I let go of the NOS button the det light goes off. Wait 30 seconds and hit the button again.
    I run a Bikeman modified stock pipe and a Bikeman ceramic coated silencer.
  8. racerdave
    1,050
    Will County, Illinois
    since 1976
    Good to see you here Pockets
  9. Pockets
    Pockets New Member
    9
    25
    Thanks racerdave. I see the traffic on Hardcoresledder isn't what it was, a lot of the technical posters are gone? Is this the new hangout?
  10. OutCast
    OutCast Active Member
    295
    Cape Breton
    I ran one on my 2014 INDY 800 that had the motor done to the nuts. As Pockets said, hit the button and skis never touch the ground. I also seen 400 RPMs gain and 3 sled lengths in 660' gain. I still have it and not sure what sled I am putting it on yet!
  11. jfaub63
    jfaub63 Member
    90
    il.
    42 years
    2015 Pro S 800
    How many hits would you roughly get out of a bottle?
  12. Pro116
    245
    Shiocton,WI
    On a 40 hp shot I would get roughly 6-7 1000-1200’ passes drag racing on a 2 1/2 lb bottle on a 80 hp shot I would get about 3 passes.
