Center shock an rear shock Removal
Discussion in 'Indy XC' started by 2cyclemech, Apr 2, 2019.
  1. 2cyclemech
    2cyclemech New Member
    18
    New Jersey
    40
    have not done this on this sled any insight would appreciated ive done this on doos not polaris looking to not make any extra work or take apart too much thanx in advance also if anyone has a part number for the polaris repair manual for 19 indy 129 x/c 850 eng
  3. Pro116
    Pro116 Moderator Staff Member Moderator
    245
    Shiocton,WI
    Your going to need to remove the skid. Remove the adjuster boldt in the limiter straps to release the preload on the center shock. Then unboldt the center shock. Unboldt the rear one and remove it.
  4. 2cyclemech
    18
    New Jersey
    40
    10-4 thank you
  5. Bassett Star
    Bassett Star New Member
    17
    Bassett
    46
    2016 Switchback Pro S
    I removed both shocks without removing the skid. Be ready/able to jack the sled up using the running boards. That takes the pre load off the rear shock. It comes right out then. Let the back of the sled hang down and you should'/will have enough room to get the track shock out.
  6. 2cyclemech
    18
    New Jersey
    40
    Ah thanx i started doing it the way ur describing an it is looking good got center out starting on rear thanx again
