Handlebar Grips Help!
Bend Dutchman
Oregon
2018 Axys 800 RMK
Hey Hey,
anyone have any wisdom pertaining to installing the stock grips? Had to replace hand warmer, bought the stock grips, and they are TIGHT! Can’t use air compressor method, because it open ended. Really frustrating.
Any help would be amazing! Thanks
Hair spray and a heat gun, heat the grip put the hair spray on the bar.
Plug the open end. And put the tip of the blowgun in the other hole. It takes a lil messing around but it will go. The pia ones are the ones with hook on end of bar. But it will go.
