Belt wear issues........
IS your idle a bit high, creeping sled?
Are you riding trails or blazing your own in a cornfield... Getting stuck often? Just getting stuck good once can kill alot of a belt's life. Folks rock the sled before inital movement, so the skis aren't frozen to the ground... Using ice scratcher can cause stuff inside the track's rollers to get stuck too. Going off trail with a sled not well suited for it will cause a belt to die quickly..... I have t blaze a 100 yard loop from the trail to my cubs hunting cabin in maybe 1 to 2 feet of snow. I had to do it with a 1" track 2010 IQ tour. I put maybe 700 miles on that and easily go 20 miles without pulling to the side of the trail... Between trailering / iced up track from scratchers / and maybe getting good and stuck 3 or 4 times, I need a belt.... Shoveling out a small starting spot for maybe 10 feet or so helps alot with that far pig with small hooves.
There is 3 critical alignments... Obviously pulleys need to be inline. But, do you have motor mount problems causing your issue? Also, shimming of the clutch.
Do you have a track in good order. All rollers / idlers good? Track isn't too tight.
There are several different belts for the IQ chassis FYI. I know there's a difference between my 2007 switchback and 2010 IQ tour, both with 600 cfi...
Coolant issues. Get some 3/8 hose and a longer 3/8 with a smooth shank, not just threads to to bolt head, and get a tire stem. Pull the hose small hose going from the throttle bodies to the overflow tank. Block off the hose with the 3/8" bolt and a clamp. Then use some of the hose and connect to the tank. Cut a valve stem down so you can put it in the hose. Add a bit of air slowly. Remove the park plugs, let it sit overnight with maybe 10 psi on it. The radiator cap should keep it below it's rating. Could be 21 to 13 psi or so.... Cleaning the radiator cap rubber face may help you keep air in it. Next morning look everywhere for leaks. A good number of IQ sleds have little radiators up front. Turn the motor over and see if you see coolant. 2 stroke sleds get alot of vibration. My 07 switchback actualled rubbed the throttle body to overflow tank line cause a slow leak.
