Maineiac
I have a Titan Adventure with about 500 miles on it. The sled is all that Polaris said it would be up until this point. Runs great on trail and off. Actually pretty amazing the way it handles on trail. It pretty much goes where I point it and usually in a hurry. My early complaint was track noise or roar. Loud track for sure. I've had long track sleds, Summits and a few Bearcats, but never as loud as this track. I did have the dealership check track tension and alignment at about 400 miles. They said it was good to go! I jacked it up the same day and found that the tension was almost 3 inches slack at approx the center of the track. Just my opinion but that is too loose for a widetrack sled. I tightened it to a little less than an inch slack with no down pressure. Alignment is spot on still. The track is much more quiet and handles so much better. I'm also running the QS3 shocks at the 3-firmest position is works better for me than the 2 that came from the shop set up. As with all new sleds they need to be dialed in, if your track seems loud check your tension early and often and you might be glad you did!
