RickyBobby
- 1
- 51
- Wisconsin
- USA
- 25
- 2015 Switchback Pro S 800
I’m running out of ideas to my issue. My 2015 Pro S problem started with a hesitation at 85 mph three weeks ago & progressively has gotten worse after 400 miles. Were it would hesitate at 3/4 throttle above 50mph. Now is does it any speed or throttle from a start and it doesn’t go away. Prior to the sled doing it all the time, took it to dealer. They replaced the belt and tested it with a new clutch and then with my original rebuilt clutch (100miles on rebuild) with no reoccurrence. Problem seemed fix. The next 50 miles the hesitation and backfire started the same way (slightly noticeable above 50 mph) and then quickly accelerated to where it does it at any speed & from a stop. It only backfires if I push it when it hesitates. Instead of letting off the throttle. Before I spend another $400 for a new belt & shop time at the dealer. I thought to reach out for help in hopes someone else had the same issue.
