David Lynch
Hi Everyone,
I just picked up a 95 XLT, and I cannot get this thing to stay running. If I spray some starter into the carbs, it will run until it burns it all off, then it will die out on me. I confirmed the pickup line in the tank is good, and the tank has fresh gas in it. I confirmed fuel is getting to the carbs, and I took the carbs out and gave them a good cleaning. I also heard crank seals could be an issue. While I had the machine running on starter from the carbs, I sprayed some starter down into the PTO seal, and it didn't change anything so I think that seal is fine. Not sure where to go next with it...
