polaris service manual,85-95
here are some timing specs.
  • timing specs.pdf
  • timing specs 2.pdf
  • timing specs3.pdf
  • timing spes 4.pdf
more timing specs
  • timing specs 5.pdf
  • timing specs6.pdf
  • timing specs 7.pdf
  • timing specs 8.pdf
igniton,charging,starter
  • igntion testing.pdf
  • ignition and charging.pdf
  • ignition and charging 2.pdf
  • battery.pdf
  • starter system.pdf
  • efi.pdf
  • efi 2.pdf
Very nice... you are killing it. Nice job!!
here are some more
  • engine electrical.pdf
  • ee1.pdf
  • EE2.pdf
  • EE3.pdf
  • EE-select monitor.pdf
  • EE-electric testing.pdf
  • EE-testing.pdf
not sure how many to put in each post so i'll break it up
  • EE-efi electronics.pdf
  • EE-efi2.pdf
  • schematics.pdf
schematics
  • schematics,1.pdf
  • schematics 2.pdf
  • schematics 3.pdf
  • schematis 4.pdf
  • schematics 5.pdf
  • schematics 6.pdf
  • schematics 7.pdf
  • schematics 8.pdf
more schematics
  • schematics 9.pdf
  • schematics 10.pdf
  • schematics 11.pdf
  • schmatics 12.pdf
  • schematics 13.pdf
  • schematics 14.pdf
  • schematics 15.pdf
  • schematics 16.pdf
  • schematics 17.pdf
  • schematics 18.pdf
last of the schematics
  • schematics 19.pdf
  • schematics 20.pdf
  • schematics 21.pdf
  • schematics 22.pdf
  • schematics 23.pdf
  • schematics 24.pdf
  • schematics 25.pdf
carb info
  • carburetion index.pdf
  • carb 1.pdf
  • carb 2.pdf
  • carb 3.pdf
  • carb 4.pdf
  • carb 5.pdf
  • carb 6.pdf
  • carb 7.pdf
  • carb 8.pdf
  • carb 9.pdf
more carb info,14.1 goes before file 14. i miss typed when numbering
  • carb 10.pdf
  • carb 11.pdf
  • carb12.pdf
  • carb 13.pdf
  • carb 14.pdf
  • carb 15.pdf
  • carb14.1.pdf
last of the carb info
  • carb 16.pdf
  • carb 17.pdf
  • carb 18.pdf
  • carb 19.pdf
  • carb 20.pdf
  • carb 21.pdf
  • carb 22.pdf
  • carb 23.pdf
  • carb 24.pdf
clutch info
  • clutch 1.pdf
  • clutch 2.pdf
  • clutch 3.pdf
  • clutch 4.pdf
  • clutch 5.pdf
  • clutch 5.1.pdf
  • clutch 6.pdf
  • clutch 6.1.pdf
  • clutch 7.pdf
  • clutch 8.pdf
last of the clutch info
  • clutch 9.pdf
  • clutch 10.pdf
  • clutch 11.pdf
  • clutch 12.pdf
  • clutch 13.pdf
  • clutch 14.pdf
  • clutch 15.pdf
There's still a bunch left,some is the beginning,stuff like identification and stuff like that. I probably should have just started at the beginning but I don't always do things as I should.:confused:
