2014 Switchback 800 (standard model) clutch recommendations?
trdehmer
Mound, MN
Friend just picked up a used 2014 SB 800, it has the stock Ripsaw II track and we put in around 106-108 studs in it down the middle...that's good enough for him.
Has all stock clutching - and his budget is tight, any recommendations for clutching that would help out to be worth it?
do a gear change to 1.71 to 1.75 area 1st
it will make everything easier to clutch,cheap way is just throw a 21 tooth gear on top and when the budget is better get 24/42 gear with a 74 pitch chain as per clutch i had good luck with 66/44 helix from my 755 fusion and rear spring will work but has good luck with 140/200 or 140/220 rear secondary spring
gear 1st
cam 2nd and spring if you do use stock
weight 68 grahams last if your revving over 8250
