Jb600rush
Hello everyone I have a 2010 rush 600 2500 miles it won't idle unless you app light pressure on the throttle, has a code for throttle position stuck , code 5201947, any ideas ?? I've adjusted the cable didn't help.
It needs to idle at 17-1800 rpm or it won't idle at all
So, adjust idle down on throttle body until you get that
Could the TPS be bad?Ok I can try that , but why would it get out of adjustment? All of a sudden? What about the Code its setting ?
