KEEP THE CAB CLEAN
This PRO XP /R fender blank off is used as a filler for the open gap in each rear wheel well for airflow to clean debris and keep the rain, snow, dirt, mud, dust, slush, and water out of the vehicle.
HEAVY-DUTY MATERIAL
Its made of 5mm thick PE board, has excellent resistance to poison and low temperature, and has good chemical stability, the inner splash fender guard mud resistance to most alkaline corrosion, waterproof, excellent electrical properties.
EASY TO INSTALL
The installation of the inner Rear Wheel Well Block Offs is simple and fast. The installation can be completed in minutes
FLEXIBLE DRILLING
RRO XP / PRO XP 4 fender flare has 3 holes on each side, and there is an optional 4th hole on the passenger side, which can be drilled with a 5/16 inch drill if necessary.
Super easy and fast installation: This is installed on a Pro R.
kemimoto.sjv.io
Exclusive 18% off discount code "AFF18" (applicable site-wide) at Kemimoto. Click link above.
www.kemimoto.com
HEAVY-DUTY MATERIAL
EASY TO INSTALL
FLEXIBLE DRILLING
![kemimoto.sjv.io](/proxy.php?image=http%3A%2F%2Fwww.kemimoto.com%2Fcdn%2Fshop%2Ffiles%2Fkemimoto-logo-1200_5d17982f-3324-42f0-b055-78d6770d61fe.png%3Fv%3D1611135630&hash=4d05675d4aaa787ed497d05a417faf3f&return_error=1)
Aftermarket UTV Accessories & Parts for SxS
Kemimoto is the leading brand in Aftermarket UTV/ATV accessories. We offer a wide selection of high-quality accessories for Polaris, Can-Am, Cfmoto, and HONDA. Mirrors, storage boxes, windshield, soundbar, gears... Upgrade your UTV and complete the journey of dreams!
![kemimoto.sjv.io](/proxy.php?image=https%3A%2F%2Fwww.kemimoto.com%2Fcdn%2Fshop%2Ffiles%2F120x90_32x32.png%3Fv%3D1663138228&hash=978a85cae1c714d946c32243b4c3e962&return_error=1)
![www.kemimoto.com](/proxy.php?image=http%3A%2F%2Fwww.kemimoto.com%2Fcdn%2Fshop%2Ffiles%2FB0103-02201BK_d3b92db1-1e7a-4567-8099-c8474b9e7693.jpg%3Fv%3D1698301496&hash=b56b531f2c3f8fc0228076efc201e3c0&return_error=1)
Fender Flares for Polaris RZR PRO XP / R (2020-2024)
The Polaris RZR fender flares are used as a filler for the open gap in each rear wheel well for airflow to clean debris. Fit for Polaris RZR PRO XP / R (2020-2023).
![www.kemimoto.com](/proxy.php?image=https%3A%2F%2Fwww.kemimoto.com%2Fcdn%2Fshop%2Ffiles%2F120x90_32x32.png%3Fv%3D1663138228&hash=978a85cae1c714d946c32243b4c3e962&return_error=1)
