New engine. Can the break-in mode be reprogrammed?
Poopoo4me
se mn
2016 Pro-s 800 w/1900 miles. So I got a new block because my ring gear flew off and raised hell with the case. Just wondering if I should see about putting the 18hr break-in mode back on? Is there a way I can prime the oil pump in my garage w/o diggy wrench? Just wondering what your opinions are on this. Thanks!!
This is what I would do, others may not agree
I would put in 100:1 fuel/oil ratio in first tank and run it hard in and out of throttle in ethanol mode
I wouldn't set break in mode again
Oil pump manual prime requires a power up harness # ps-47296-b and battery
We can flash whatever length break in you like if you have one of our Bullydogs.
Sent from my SM-G925V using Tapatalk
