PCV question
Newton978
Massachusetts
2017 Switchback 137 800 LE
2016 Renegade 1200 X
I have a pcv with ignition and pod-300 display will I be able to see the afr value on the display without the auto tune kit?
I have the same system you will need the auto tune that comes with the o2 sensor and bung weld the bung on your pipe and plug the o2 connector into the PCV
Or use a WB2 unit has more features, if you have a need for them.
^^^^^ Agreed you will need Autotune or Wideband 2 module to connect with PC5 because the POD300 only reads available channels and the PC5 does not have a AFR channel until you add one of those.
