Re-Gear needed?
hirevn
ALASKA
I have read through most of the gearing/clutching threads here and still somewhat confused on the gearing. It looks like most of the talk is around the switchback with the ripsaw/cobra track and 1.61 ratio needing re-geared when your adding clutching.
I am wondering from the experts here if the Pro X (back country track) with the 22:41-70 gears (1.86 ratio) is also recommended a re-gear when adding a pipe and clutching?
YOU CAN CLUTCH IT AND KEEP THE GEAR THE WAY IT IS IF YOU WANT. THE PIPE WONT HURT IT EITHER, WILL JUST MAKE MORE POWER AND ACCELERATE HARDER. UR TRACK AND GEAR WILL BE UR LIMITATION FOR SPEED..
before a gear change on the pro x im curious what the gates belt will do being a little thicker and helping shift to overdrive? i am still tinkering to get full shift in primary
I will be dialing in my clutches for the gates belt next week, the shop that shimmed it for me set it to wide at around .035" so it is going back to have one of the .020 shims removed.
