Wondering how much has changed with this new 2017 Axys motor. It seems Polaris has re-written the ECU with some new parameters. Guessing in 2015 when they unveiled the new H.O. motor they had some serious safety precautions set to make sure this new motor was durable and not one that would have lots of motors blowing up. ((There were some issues but it proved to be strong.)) In 2016 it seemed they erased the problems that were evident in 2015 and I didn't here much for complaints from buyers. I had a 2015 Pro-S 800 which I traded back in because it had the light switch fade issue. Polaris couldn't seem to fix it and I'm not a mechanic. I wasn't about to pay someone to try to fix my Polaris warrantied sled. My 2016 Pro-S 800 and SKS ran great and I still have the S. So this year I bought the new 2017 Assault. I'm seeing what everybody else is seeing. This thing is an animal compared to my last two year sleds. It isn't just the Assault from what I've read and heard. Any model with the H.O. 800 is ripping hard with much higher RPM's than the two years past. Everybody seems to be pulling 8400-8550 and many of these aren't even out of break in. So here are my questions...
1. What is the target rpm for people running stock? Still around 8200?
2. I've put the SLP pipe on and installed Ricks "NorthStar" Stage 2 clutch kit. I've got the Daltons adjustables set between 70 and 71 grams and she is still pulling 8400 with ease. She isn't out of break in yet either. With the extra HP the pipe is pushing anybody have a rough idea what RPM I should be targeting? I've dragged her down to 8300 with more weight but brought her back up to 8400-8450 because the pull seems so much harder there. I'm thrilled with the set up and this Assault has some serious traction for both take off and braking compared to my Switch S. Other than the IGX rear suspension being a "little" harsh.... What a sled!! She will suck up the trash bumps amazingly. I'm going to let everything break in a bit before deciding what I'd like to tweak there. I'm 300lbs fully geared and running all settings Low.
Sorry I got sidetracked... Back to RPM's
