OutCast
This guy on "the other forum" going on how much of a rocket his AXYS 800 is with a 1.5 gear ratio... WTF
Someone enlighten me if its true a Polaris 800 goes better with a 1.5 ratio than a 1.68-1.74 ratio??
Hers a copy and paste of the conversation:
Stock is 22/37, gearing the machine 3 teeth taller and still able to use stock 68 chain ..24/36 is gearing but there is clutching that goes along with this combo..
MY RESPONSE: You are not "3 teeth taller" to speak exactly. You are 1 tooth count in the difference from stock. 59 teeth on the stock gears to 60 with your new combo. No stock chain can fit a 3 tooth increase.
With a 1.50 ratio Your sled must be a slug on the bottom to mid range.
Does it take you 3 miles to get at 116mph? A 1.50 ratio is craziness!
HIM: Ok I have to get off and push it to get it going then it s ok just like my 1100 turbo programed at 300 hp 131 mph on gps in 1800 feet I guess it's a slug to . What a joke to many no it all's lol
Maybe you should ask the doo guys that I ride with how much of a slug my pro s is they can't seem to ever get out front out of the gate midrange and top end xrs craps out at 105 and then it's see ya...
