Romulus91
- Messages
- 2
- Age
- 34
- Location
- Canada
- Country
- Canada
- Years Snowmobiling
- 20
- Snowmobile
- 2015 switchback assault 800
Having an issue i just cannot figure out on this machine. Took it for a ride a week ago saturday. 112km into the ride it just died and would not restart. Trailered it home and put it in my heated garage. After lots of testing and thinking figured out the sled was only outputting 11.4V. Was able to supply power straight to fuel pump then it fires right up, Follow up testing probing power at the plug for my heated visor proved low voltage. So thinking stator or regulator right? .... Well.... Tested once more to just be sure sure and wouldn't you know as im testing voltage I watch it jump up to 14.4V. unhook direct power to fuel pump and it runs... Perfectly..... Started and shut it down 10 times with no issue over a few days. Took it for a 10km ride no issue.... Rode it all day yesterday and again today. 200km later it did it again. Sled just died on trail. No hesitation or warning signs just bam like I hit the kill switch (didn't! I promise) Trailered it home again. Inside the garage, Hook power straight to fuel pump it fires up. Test voltage shows 11.4V again. wiggle some things around thinking maybe by some dumb luck its a pinched wire or something. No change, but then a minute later its running at 14+V again?... Am I onto something with a broken wire grounding out anywhere? Any known weak points i should check first? Anything else it could be? Or am I just wasting time and this is a stator crapping out?
I'll mention as well the sled is completely stock without any add ons or mods.
