1994 Indy Classic EFI flooding
Cbaker
Northern MN
1994 polaris classic touring
I use this sled for ice fishing. Sled starts with out problems if it has been sitting overnight. When I ride the sled out fishing usually a couple miles,and shut it off after it has set fore 2-3 hours when I go to start it will some times flood and is really hard to restart. I don't want to be left stranded on the lake. Any thoughts or suggestions.
DO you try to start without choke even if sled sits 2-3 hours? Had '97 600 which flooded real easily on choke, and was a b..... to start.
This is a EFI so there is no choke. I am thinking it may have a leaking injector. Anyone know how to check for injector leaking
Leaking injector - maybe. My bet would be a bad CDI. I’m
If you hold the throttle wide open your computer will turn off the injectors this will help you start after a couple pulls . On the block is a temperature sensor. If the engine is warm and the sensor thinks its cold the system will inject too much fuel.
