2009 Polaris IQ Shift-Heated Shield
Discussion in 'PSP News/Site Help' started by BuckyB, Dec 17, 2019.
  1. BuckyB
    BuckyB New Member
    Massachusetts
    35
    2009 Polaris IQ Shift 600
    I have an 09 Shift no electric start. New Oxygen Helmet doesn't work with sled. Checked the helmet on my 18 ZR8000 and helmet works with no issues. Changed cords still the same. Could it be the voltage regulator? Any advice is welcome. Thanks
  3. MrSled
    847
    Have you tested the out put of the connection with a tester?
  4. BuckyB
    BuckyB New Member
    Massachusetts
    35
    Yes, reads 12volts at idle, changed voltage regulator tonight and still not working, not sure what to do next.
  5. MrSled
    847
    Strange, if you have 12 volts at the plug then it has to be the chord or the helmet. Is it pushing enough amps required to run the heated shield?
  6. busted 900
    busted 900 New Member
    6
    connecticut
    2005
    fusion 900
    not sure if you fixed your machine but just going to throw this out there, maybe the jack is worn and needs to be replaced. that would be my guess, plug and unplug over the coarse of time will make the internal contacts change shape. hopefully this helps.
