2009 RMK 600
Tylerbadger
Nl
2009 RMK 600
Hey guys, new to the page. Recently picked up a 09 rmk 600, whats some things to look for? Common problems??
Did a compression test on it and only showed about 112 psi on each cylinder. Normal or low?
Thanks
Administrator
Admin
Thanks
Welcome to the site!! PSI can vary depending on the gauge as well as if you hold the throttle wide open as you test pressure. Sounds a tad on the low side. Was it a cold motor?
Tylerbadger
Nl
2009 RMK 600
New gauge but the throttle was closed and cold engine! Wasnt started in 2 years apparently
