2015 Indy 600 SP Boggy
psmith64
Eau Claire, WI
2015 polaris 600 Indy SP
My sled runs fine but when you go to can the throttle at mid range is bogs down, Any ideas??? I have changed spark plugs and gas.
psmith64
Eau Claire, WI
No i haven't it has 2500 miles on it, took it out last night for a test, if you pin it is maxs out at 6700 rpm, if you go just under full throttle it runs fine got it up to 80mph again you just cant pin it. I havent looked but the power valve is on each cylinder head?
Pro116
Moderator
Moderator
Shiocton,WI
Yes each cylinder has it’s own power valve. I suggest looking on YouTube how to take them out and clean them. I have seen issues as your describing from gummed up power valves.
