2015 pro x 800 shutting down
cmjw1975
Manitoba
Problem: Check engine light comes on and sled immediately stalls. Typically happens the first time after longer runs of 15-20 miles. Seems to happen when I let off the throttle or reduce RPM's. After it happens once it seems to happen often until I let it cool down, seems like it only happens after it is warmed up nice, higher speeds, (even though the Temp is always around 120- 127).
I can usually restart immediately, but after several failures in a short amount of time it doesn't want to start unless I hold the throttle wide open...typically can limp home a low speeds. If I let it sit and cool over lunch etc...it seems to be good for another longer run.
I appreciate any input.
