850 patriot throttle problems
JImmy Lundmark
Skellefteå
Swedan
Polaris 850 SKS 146"
Hi.
Anyone else who has problems with the throttle? When you go around 5000-6000rpm and release the throttle it's still hangs on in about 1-2 secs.. If so, what have you done to get this problem solved?
Administrator
Admin
Hi.
is RPM or is it throttle, it could be not back shifting fast enough when you let off.
Markconacher
Calgary
2019 850 patriot sks
Mine does the same, the throttle releases but the sled acts like it’s powered in cruise control for a few seconds. Seems to get worse the colder it is - have not identified a fix as of yet, any ideas welcome
Bigfuse
Moderator
Moderator
Sunny Manitoba
2020 IndyXC 850
Have you taken it to your dealer?
stonzy
35 yrs
2020 850 Indy xc
Hi guys I’m new to the forum. I too had this ghosting throttle issue as well as det codes coming up quite often. Took sled to dealer as well as contacted Polaris. New flash was installed at dealer. 400 miles later and the results are: no more det codes. Sled seems quite a bit stronger. Ghosting throttle gone. It does however seem to load up with fuel when coming to stops. So much that when shutting sled off at a break it will sometimes backfire on start up. I’ve reported my findings to Polaris and hopefully they will tweak flash a bit more. Want it to run like my wife’s 19 800 xc
Marcus Morrissey
NL
Polaris & Arctic Cat
Just got my '19 flashed as well, SSA-19-02. Had a small run tonight and seemed ok but need more seat time.
Was running like junk for a little ~30 hrs changed plugs and much better then flashed. Was told to swap in new plugs but haven't yet.
P.s outgoing plugs were fouled and black.
