brianxc700
last fall i pulled carbs and took bowls off and sprayed them out with carb cleaner and replaced all fuel lines .didn't fire it up till now . cold it fires up sitting there warming up at idle it hiccup's and dies . if you give it some throttle before hand will stay running but bog's down a bit and just smokes fiercely . rode it and it runs very well no problems mid range or top end . while it is hot idling no smoke but after 15- 20 seconds it will hiccup and die . rideing and stop and idle 6 seconds it ok seems like the longer it idles is when it dies . pulled the plugs and they light tan perfect not to rich .
cold it only idles about 1100 rpm i thought about turning the screws with black knob on the side in a bit should make it idle faster? theses are the keihin d slide carbs they were pretty clean when i pulled the bowl off the bottom . any input on this appreciated
