JohnnyBravo
Can I perform this test to check that the belt goes to the top of the primary with sled on a lift or does motor need to be loaded?
You have to load the motor.Can I perform this test to check that the belt goes to the top of the primary with sled on a lift or does motor need to be loaded?
Load motorCan I perform this test to check that the belt goes to the top of the primary with sled on a lift or does motor need to be loaded?
