Thought I would start a thread with some advice on breaking in your axys.
I took a trip up to maine for the weekend to break in my sled. For starters I highly recommend going through the sled and checking everything. One thing I think that is very important is the clutch alignment (float) and cleaning them properly. I followed brocks clutch alignment procedure and also added some more total float just because and the clutches work flawlessly. I also scuffed them up with a light scotch brite pad, cleaned them many times with acetone, and washed the belt with dawn soap and tough scrub brush. After 100 miles the clutches look like they were never used, not a belt mark on them and run very cool.
Now for break in procedure. I talked to Jim at dtr and he says these motors with the chrome rings need to be riden hard right away to seat the rings properly. His words were the "the harder you run it, the better it will run, hammer down!" So that's what I did, I don't think ive ever ridden so hard in my life haha, however it definitely works. Its cool to watch the rpm gradually increase as the rings seat and the motor breaks in. The motor now goes to 8350-8400 every time I punch it. I had filled the sled with 93 ethanol fuel 2 months ago with the proper oil amount because I had to store the sled in my trailer and didn't want any moisture to build up in the tank so I filled it to the very top. I ran the sled in (91 non) mode which I would recommend as it definitely makes it run better during break in. After the 2 hour break in and the fuel amount decreases I got one det so I just pulled over, shut it off to reset, and put it in (ethanol mode). The sled runs like an animal and maybe runs even better in ethanol mode, could just be that the fuel was a little old. Put on a total of 100 miles so far.
Hope this helps anyone who had questions.
