Caster Ajustment
wisted
Germantown,WI
Can anyone with a service manual verify what the correct way for adjusting the front lower and upper A-arm bushing shafts. I have a operating manual and have adjusted them as follows:
1. Loosen the four lock nuts. 2. From the bushing side of each pivot, push the pivot toward the control arm. 3. While holding the pivot(s) in place, tighten the lock nuts. Torque: 30 ft-lbs (41 Nm) Do the same for upper and lower.
The problem I see with the above is caster will be all over the place dependent on where you are placing the upper compared to the lower. Is there a starting point i.e. lower pushed to the back, upper pushed to front or both pushed to the back.
Thanks
First off welcome to PSP. A growing community of Polaris gear heads.
As to your question, that's a good concern. As much as I've worked on Polaris sleds over the years,
I've never seen caster addressed.
Camber has always been a concern as well as toe-in (or toe- out in this case).
Hopefully someone here can answer your question.
