Phipp
- 3
- 54
- Wisconsin
- USA
- 25
- Polaris Rush 800 S
Hello, I'm a new member....looking for any input or advice. 2015 Polaris Rush 800 S
Problem: Check engine light comes on and sled immediately stalls. Typically happens the first time after longer runs of 15-20 miles. Seems to happen when I let off the throttle or reduce RPM's. After it happens once it seems to happen often until I let it cool down, seems like it only happens after it is warmed up nice, higher speeds, (even though the Temp is always around 120- 127). The shop has tried new TPS sensor, new throttle cable???
I can usually restart immediately, but after several failures in a short amount of time it doesn't want to start unless I hold the throttle wide open...typically can limp home a low speeds. If I let it sit and cool over lunch etc...it seems to be good for another longer run.
I appreciate any input, I'm not much of a mechanic but I could share your advice with my dealer.
Thanks!!
Thanks!!
