ProX00
I bought a compression tester at Harbor Freight today. It was only $30. I went home and wanted to test it out. I removed a plug and installed the tester,turned the on/off switch on, and gave it a few pulls on the rope. The best I got was 80lbs after testing several times and each time I tested I got 80. This seems low! What psi should I be looking for? Did I even test it correctly? The sled only has 2000 miles on it and runs great so there is no reason to think the compression is low! Oh, and I tested teh other side and it is only 70psi.
