Anyone have any experience with these CPC weights?
POLARIS ADJUSTABLE CAM ARMS IMPROVED TRAIL (IT)
Improved Trail (IT) Cam Arms replicate the factory cam arm profile and shift characteristics. IT Cam Arms are de-
signed to be used in mountain and high elevation applications. IT Cam Arms up-shift and back-shift identically to
factory cam arms, except they can be adjusted for weight. IT Cam Arms match the factory weight gram for gram.
You can now adjust the weight of these cam arms in seconds by simply adding or subtracting set screws. It’s that easy!
This new generation of cam arm is manufactured specifically for the new Polaris clutch. The accessibility of this adjust-
ment can be made without the removal of the cam arms or drive belt. You can now purchase one set of cam arms and
have the ability to add up to 8 grams of weight. Each kit comes with an assortment of set screws. Adjustments are made
with the included Allen wrench.
POLARIS ADJUSTABLE CAM ARMS TURBO MAG (TM)
Turbo Mag (TM) Cam Arms are more aggressive than the factory cam arm profile and shift characteristics.TM Cam
Arms are designed to be used in aggressive trail riding and turbo charged applications. TM Cam Arms are ideal for
drag racing and have a very aggressive up-shift nature. TM Cam Arms act 5 grams heavier than the factory weight
and must be ordered 5 grams lighter weight (i.e. 70 gram TM weight acts like a factory 75 gram weight and runs at the
same RPM as a 75 gram factory cam arm weight).
You can now adjust the weight of these cam arms in seconds by simply adding or subtracting set screws. It is that easy!
This new generation of cam arm is manufactured specifically for the new Polaris clutch. The adjustment can be made
without the removal of the cam arms or drive belt. You can now purchase one set of cam arms and have the ability to
add up to 8 grams of weight. Each kit comes with an assortment of set screws. Adjustments are made with the included
Allen wrench.
CP-000-6070P 60-70 GRAM $179.95
CP-000-6575P 65-75 GRAM $179.95
CP-000-7080P 70-80 GRAM $179.95
CP-000-7585P 75-85 GRAM $179.95
Allen wrench.
