Gates belt
fall river ma
2016 switchback pro s 800
so I hear that this gates belt is a better belt and obviously much cheaper than oem. So my question is, is it really better, and will it work on my 16 switch? Part #46c4387. I can get it at local O Reilly auto parts for $95 vs $200 oem, thoughts and facts ?
Im using the gates belt on MY15. Definitely grabs and performs better imo. I did however blow a gates belt after a hard 100 miles or so. Idk if it was a bad belt or what the deal was. Current gates belt has a hard 200 n still looks good. 2 gates belts is still cheaper than 1 oem belt. Im sticking with the Gates belt
But which belt I see 3 on gates website. I posted a pic of them
Gates work ok. 4 of us raced for over 700 miles with them with no problems.
We all have alignment and offset set perfectly which helps any belt.
The gates is slightly softer compound then the poo belt and about 0.0030"
Wider
Epi is now making belts too
Ultra max makes a belt too.
Polaris is making new belts as we speak, I don't know if it's a different compound , but I'm guessing so as the current belt is hard and gets glazed over causing guys to search for other problems as it slips up top(3/4" to top)
Polaris is aware of this and will we see the new belts that have been tested? I don't know?
Ohh, measure pitch length.
I have a thread on it somewhere
So it's now proven that it's the pitch that is the key measurement. Thanks guys that was some good research and a great piece of info.
You can use a cloth tape like doc says.
But I'd only use that method comparing Polaris to Polaris or gates to gates, etc
Pitch length measuring is best when comparing different brands with each other for accuracy
