Dr.Notadoo
This is what I have found to work the best so far : front clutch 66 grm Cat weights with 2 grms added to base , stock spring, stock belt re shimmed( Cat weights are tucked more then Poo) 68 total. Rear clutch 48-44 full stock spring. 21-39 gear(1.86) stock chain and IQR tensioner . SSI pipe mod and pcvwith DTR hot map. Every else factory
