Switchback_Johnnie
- 1
- 51
- Winnipeg, Manitoba, Canada
- Canada
- 42
2011 Polaris Switchback Assault 800
2007 Polaris IQ 600 HO
Hi All
I have a 2007 IQ 600 121" and recently had some issue with the secondary overheating and some noise. I removed the clutch and speedometer housing to inspect bearings and freed up and cleaned the jackshaft bearing cleaning out all the grease. The bearing on this side is a sealed bearing and this machine has the electronic speedometer pickup. The grease nipple was not installed in the spot the service manual says, but I re-tapped and re-installed it and replaced the gasket on the a shaped bearing collar. Does anyone know if this housing needs to be full of grease when operating? I can see it with the mechanical speedometer and I used a needle to grease inside the small orifice on the bearing seal. I am hesitant to grease this housing as it will take a lot of grease to fill and I don't see what purpose it serves. If someone could let me know what they think that would be great. The service manual is really very poor.
Thanks a bunch
Thanks a bunch
