Low coolant temp
Maki
Michigan
2020 XC800. 2018 pro s switchback 600.
2020 xc 800 runs around 113 to 118 degrees coolant temp. Will go to 130 if left to idle. At WOT will cut power at about 70 mph. Bad thermostat,temp sender or what else? My 600 runs 124 degrees all day.
Administrator
Admin
Could be thermostat or blown head gasket.
850Switchback
CT
2020 Switchback XCR
All the redesigned motors since 2018 run lower temps, cant go by what the older 600 runs. 800HO got a new head design & stat in 2018 and they run more like what you are seeing.
Ran ny 850 all day today between 99 and 110.
850Switchback
CT
2020 Switchback XCR
Did you change out the electrical relays yet? The relay that runs the power valves could be shot.
Mike Klem
Dryden, Ontario
2020 Polaris 800 Indy XC 137"
My 2020 800 XC 137 runs at 105 degrees F (41 C) as it's normal operating temp. My 2015 600 Switchback Adventure ran at 125 degrees F (51 C).
