Mag side fouling plugs
Discussion in 'Rush/Switchback' started by Brian Yenser, Feb 21, 2021 at 8:38 PM.
  1. Brian Yenser
    Brian Yenser New Member
    Pa
    15
    17 polaris sb pro-s 600
    I have a 17 sb pro s 600 3200 miles runs great but been fouling mag side plugs. Will go 200 miles strong all day turn next morning foul a plug warming up. Comp is 115 both cly. I’m lost in what it could be like I said it runs hard and strong. Injector? Seal? Coil? Maybe just some sea foam ?
  3. Rbell14
    Rbell14 Member
    85
    Plymouth, Mi
    10
    2021 Indy VR1 850
    2016 Rush Pro S 600
    I'm experiencing some issues on a similar sled, just curious once the plug is fouled I assume it's obvious with one cylinder firing. Mine seems to idle and run good but seems like it's missing some top end power. Don't think it's a plug, suspect my exhaust valves need to be cleaned.
    Your plug only foul out while warming up?
  4. Brian Yenser
    Pa
    15
    Mostly on warm up when I go to pull out of camp it could mag side I replace plugs runs good all day then when cold again it does it again. Idk. It had fouled in middle of a ride already also but only once.
  5. 850Switchback
    850Switchback Member
    34
    CT
    2020 Switchback XCR
    I would start by running some sea foam or K100 through it, could just be a crappy spray from that injector not atomizing the fuel.
