PC V on a AXYS? Where?
racerdave
Moderator
Moderator
Will County, Illinois
since 1976
Where are guys mounting them on a AXYS. Pics?
ECU....upper right corner. Plenty of clearance and doesn't cover any of the serial/part #'s. Zip tie the wires to make it look clean. Run the ground down the carbon fiber overstructure and connect to the rear most front bumper bolt.
Here it is
Yep, but I always do whether or not the particular sled needs it. Cheap insurance.
It looks like you vent line has a check valve. One way? On the grommet, does it have a inner lip to help seal/hold it into the tank?
Ya I bought a kit from Rick over on HCS and it is good stuff. Just didn't think the need was there anymore. DId it on my pro-r but never thought twice on the axys. I wonder if more guys are doing this?
Almost positive the line has a check valve. Unsure if it's one way or not. Yes, on the grommet. All I can tell you is that is works! Installed on many prior sleds. Just one of those things that's over looked that I add for piece of mind.
