I was thinking about this, so you mod your motor and it needs more fuel, which you can add using a PCV. But the ECU also is controlling the electric oil pump on the AXYS 800. So your adding fuel with the PCV but not more oil? How much more fuel can you add before you are running too lean?
Or is this something that I shouldn't worry about because it has plenty of oil in factory map that adding some fuel won't lean it out to much? Or would it be a good idea to mix some in tank? Which I don't even think would help because it won't get to where it needs to go being a motor designed for injection
