jfaub63
2015 pro s. I'm still having poor (low rpm rough) idle issue. Does not do it in reverse idles fine @1750. does It with the belt on or off. Heres what has been tried . TPS has been set at least 10 times(dealer and myself). throttle blades backed off. base setting is spot on idle has been tried from .915-940 no luck. Top end is all new-still same as before. it does it with stock tune and with my bmp tunes( tried a few). new fuel sock. plugs exhaust seals up great new pipe sensor etc. injectors were removed and spray pattern appears to be fine. give it a little throttle and its fine it will idle perfect all day in reverse. other than the idle it runs great. any help is appreciated.
