Power Valve Question
Powaton
Ny
Pro S 800
This may be dumb, or covered before, but I can't find any information.
I'm changing my gears and making sure my exhaust is sealed. With the exhaust off, I couldn't keep my grubby and curious hands away from the valve servo motor arm. I ended up moving the arm.
Was this a stupid move?
When the machine is started, does the valve servo motor home itself?
Thanks.
You can move the cable on servo motor , don't worry about that.
Cable " full in ", "full out" should be tested more along with e ves signal converter if any problems detected with any value problem
