MSAREV
- 27
- 51
OK - here goes. 2015 PRO-X Switchback - I was very happy with the performance with the "stock" clutching last year for the 2000+ miles i rode it. Since I am not going to swap track & gearing this year like i wanted to - i will run it again with the stock backcountry X and the 1.86 gearing. I plan on removing the primary clutch to replace the spring and check & clean everything else....should i replace the spring with the stock "gold" spring ?? ( part#7041148 ) or is there "better" replacement spring when using the stock weights & rollers and secondary set-up ?
Thanks in advance - Matt
