reaches temperature and stalls
MR INDY
Toronto
32 yeras
2016 Pro S 800 switchback
sled stars idles fine reaches temp and will stall pulled plugs pto side flooded checked tps change a fuel filter and sock after changing those things sled starting acting up would try to stall when letting off and has got worse any thoughts
not that type of issue as soon as it hits 100 it will die
I bet ur tps idle is way to low. Plug fouling tells me this .
rest the tps had a ground issue found 200 Rpm rode Sudbury to Elliot lake today ran like a champ two issues but the tps was off thanks Brock
