cs641
I have an RMK600, not sure if it's a 99 or an 01. Anyway I had someone working on it and they gave up so I am replacing the fuel lines. Can someone provide a good fuel system diagram for the 600? Essentially trying to figure out the two nipples (vents?) on either side of the carb and what they should be hooked up to. There is a line from the top of the fuel tank that is not hooked up to anything, as if it's a tank vent, do these nipples tie into that line? Also, the MAG side carb has a hose barb that isn't hooked up to anything towards the air box.
Thanks for the help.
