- Messages
- 1,087
- Age
- 69
- Location
- Will County, Illinois
- Country
- USA
- Years Snowmobiling
- since 1976
- Snowmobile
- AXYS Switcher 800,Indy600sp,XCSP600ves
Anyone using them? Good/bad? And yes I just seen them on the site many here love to hate.
Not that I hate slp weights at all. Their weights are purpose built for high elevation and mountains.
Things get way different near sea level and trail riding.
Maybe the new weights are good for low elevation flat land trail riding??
The mtx are a flatter profile to keep revs up in higher elevation. What weights are you talking about?
Different ways to clutch for sure. It’s not about picking someone’s set up on here and saying yours is faster? Anyone can say that?
I like a more aggressive profile then slp and lighter springs then you’re using. We can all clutch different but get fast sleds
How much weight are you running in th and what is your engagement at?They aren't a high elevation weight. Spoke with SLP about this before buying them.
I have tested these weights against a lot of stuff that has been posted on here. Run the stock helix and 140/220 secondary with 160/340 primary or something close. Mine shifts out at 8150-8200 builds to 8400. Nothing bad to say about them. Faster than alot of stuff posted on here. I have a 17SBA aggressively studded.
I have found even when loading up a more standard profile weight I still cannot get it to accelerate as good as the more aggressive profile. The more aggressive profiles are not as forgiving to conditions changing and getting them setup is not as forgiving so there are some tradeoffs. For all-out top speed only running I would not run the more aggressive profile.Understand the above for a traditional non adjustable wt, but it seems that the profile becomes somewhat less important with adjustable weights. For example, if the weights profile is aggressive then the amount of weight that will need to be added is less than a weight with a less aggressive profile.
Yes I do!Fastsledder has. Said he liked them.
Anything to report Fast?Yes I do!
I did notice I lost some top end. Corner to corner they kick ass. I'm goin to pull them out and try some Turbo mags.
