monte44
- Messages
- 12
- Age
- 45
- Location
- Minnesota
- Country
- USA
- Years Snowmobiling
- 30
- Snowmobile
- 1995 indy sport, 1996 indy lite
Working on a 1999 carb fuji indy 500 for friend. Was brought to me for being boggy and no power under load. Does idle nicely but boggs almost to the point of killing the engine under load. Found low compression in clutch side cylinder so after rebuild and new crank seals the sled is acting to same as before the rebuild. Here's a list of what I've tried with no luck from another running indy 500. I'm stumped on this one? HELP!! LOL!
clutches
CDI,Stator
exhaust pipe
fuel pump
carbs
bypassed throttle safety switch
engine has 125 compression
passes leak pressure test
hooked a remote fuel bottle to try
timing is in within "book specs"
clutches
CDI,Stator
exhaust pipe
fuel pump
carbs
