Dr.Notadoo
HEY GUYS,THIS IS MOSTLY A THANK YOU POST FOR TED. I COULDN'T BE MORE HAPPY WITH THE JOB HE DID WITH THIS PROJECT. JUST SO I DONT STEP ON ANYONES FEET AS I SAID I WOULDN'T GET TO TECHNICAL IN MY REPORT. ON TEDS END THE WORKMANSHIP IS TOP NOTCH, EVERYTHING HE SAID HE WAS GOING TO DO WITH THE MOTOR HE DID EXCEPT DYNO IT.THATS OK AS HE WAS VERY BUSY AS ALOT OF YOU GUYS KNOW THAT TRIED TO CONTACT HIM. THE MOTOR IS VERY STRONG AND CANT WAIT TO LINE UP AGAINST SOME OTHER PEOPLE AND SEE HOW IT PERFORMS. I DID RUN MY BUDDYS PIPED ,CLUTCHED,AND GEARED AXYS AND HAD HIM BY OVER A BUS LENGTH,AND I WENT ON HIS GO. THE PISTON SPEED ON THE STROKER IS AWESOME..ACCELERATES VERY HARD. I AM RUNNING A JAWS SINGLE WHICH I LIKE ALOT WITH THIS PACKAGE, THIS IS WHERE I WAS ASKED TO BE DISCREAT: AT 8400-8450 THE MOTOR MADE ALMOST 20% MORE HORSE POWER AND TORQUE OVER STOCK. THIS IS A GREAT GAIN OVER STOCK. THESE # ARE RAW HORSE POWER AND TORQUE, NO CORRECTION!!! BEST OF ALL I CAN RUN ON THE TRAIL WITH STOCK MAPPING WITH NO ISSUES IN NON-ETH MODE. FOR THE LONGER RACES I USE MY MAP SWITCH TO ADD SOME TIMING AND FUEL TO BE ON THE SAFE SIDE,AND ONLY AT 100% THROTTLE.
