Thoughts on this new clutch prodcut from Bikeman?
Discussion in 'PSP General' started by MrSled, Aug 10, 2018.
  1. MrSled
    884
    Whats your thoughts on this?
    Bikeman Performance
    •Decreases belt temp, prolonging belt life
    •About 25 CFM above stock down low
    •Up to 50 CFM above stock at full shift-out
    •Constant cooling, direct on the primary clutch
    •Billet aluminum construction, built to last
    •Designed and built at our state of the art facility here in the USA
    Compared to the inline clutch blowers, our CYCLONE never hinders airflow. Inline blowers generate more CFM than stock at idle, but once the CFM of the clutch housing goes above the CFM of the inline fan, the inline fan actually becomes a hindrance. This is why we went with a fan within the clutch housing on the primary clutch. Since the primary clutch always has RPM, the fan will always be generating airflow, constantly cooling. Our airflow increase over stock is about 25 CFM down low and up to 50 CFM at full shift-out. Above 250° belt life begins to decrease, above 300° you have minutes left and above 350° your belt explodes.
  3. jfaub63
    jfaub63 Member
    90
    il.
    42 years
    2015 Pro S 800
    Cooler belt temps is always a good thing. This extra cfm must cost HP although it may be minimal. any idea how much this HP loss is?
    MrSled likes this.
  4. MrSled
    884
    Not sure. I was waiting to see how it all pans out once its in production.
  5. rabbi
    rabbi Active Member
    253
    Tomah, Wisconsin
    38 Years
    2016 600 Switchback Adventure
    I would think the clutch would need to be rebalanced once this cover is installed. The original cover is indexed and is balanced with the rest of the clutch as a unit.
    Bigfuse and MrSled like this.
  6. racerdave
    1,060
    Will County, Illinois
    since 1976
    Can't play vid.
  7. MrSled
    884
    Works for me. Could be your browser.
  8. Lenn Johnson
    Lenn Johnson Active Member
    111
    Pembroke NH
    I like the design. Don't need to rebalance the clutch with this cover. I ran another manufactures cover last season without rebalancing with no issues. I've had my primary balanced in 2016 on my Night Lightning Pro S and my 15 Renegade and did not notice any difference before or after....including any sort of performance gains. I thinks it's a great idea for guys running more HP and RPM, but for a stock sled, the gains are minimal.
    MrSled likes this.
  9. racerdave
    1,060
    since 1976
    For me the main reason to balance is to help the motor from vibrating. 800's shake plenty from the big holes in the cylinders.
    MrSled likes this.
  10. Lenn Johnson
    111
    Pembroke NH
    The clutch cover from Bikeman shown is on a UTV, not a snowmobile.
    MrSled likes this.
  11. MrSled
    884
    My understanding the sled covers are in the works.
  12. coryatver
    coryatver Active Member
    378
    PA
    Indy dan had similar covers and everyone that had one had big problems. Yeah you definitely need to balance your clutch if you install one. It spins at 8,300 rpms you need the clutch to be balanced which the oem is done at the factory but changing the cover will throw it off. My opinion Polaris has the best clutch setup out there that just plain works don't screw it up with aftermarket pieces
    MrSled likes this.
