Top End Bog. 2018 800 XCR
Discussion in 'Rush/Switchback' started by Wilmotriverside, Jan 7, 2020.
  1. Wilmotriverside
    Wilmotriverside New Member
    19
    Twin lakes wi
    2018 800 xcr rush. 2800 miles. Always ran great now falls flat on its face on grades right around 7100 rpms. Kinda like a bog. Is there a fuel filter on these that may need replacing or could it possibly be exhaust valves not opening?
  3. Rbell14
    Rbell14 Member
    96
    Plymouth, Mi
    10
    2021 Indy VR1 850
    2016 Rush Pro S 600
    I recall reading about cleaning the exhaust valve on my Rush. I have not done that but wondering if you should check that. I think it called this out in the owners manual, give it a check. I’m sure there is a simple fuel filter but not sure where it’s located.
    MrSled likes this.
  4. Xcrules
    Xcrules New Member
    Östersund
    Swedan
    50
    XCR 800 2018, Rush 800 LE 2014, XCR 440 SP 1996
    I have the same symptom with my XCR 800 2018. Always shifting at 8200 +- 100 rpm. Now only 7300. It happened mid-riding. No fault codes. It runs strong on half throttle as before. At the same time I got an oil leak around the primary clutch. I suspect the crank seal behind the clutch. The oil is clear, i. e. not coming from the exhaust.
  5. Rbell14
    Rbell14 Member
    96
    Plymouth, Mi
    10
    2021 Indy VR1 850
    2016 Rush Pro S 600
    Did you find a solution to this issue yet? My 600 Rush is doing the same thing now. I'm gonna clean the exhaust valves and see if that solves it. I have 3,700 miles on it and have not cleaned them yet so I'm thinking that's the issue.
  6. Rbell14
    Rbell14 Member
    96
    Plymouth, Mi
    10
    2021 Indy VR1 850
    2016 Rush Pro S 600
    I cleaned my exhaust valves and my top end performance is back to normal on our 600 Rush.
  7. jfaub63
    jfaub63 Member
    107
    il.
    42 years
    2015 Pro S 800
    check your exhaust valve cable to see if has broken. This is common and it will not always set off a code.
