It’s worth noting that in order to install this bag you need to remove the stock spare belt holder but they supply a zippered pouch on bottom/side of the new bag to store your spare belt, plugs, and plug wrench.
I have plenty of room after removing the stock can. I think i'll try to mount something on the crossbar over the pipe. I can probably zip tie a small bag to it.
FYI if you buy the bag and don’t have a stock pipe you might have to modify the bag heat sheild depending on where EGT sensor is mounted my BMP PIPE has it coming out the side. I simply drilled a 1 inch hole in side of heat shield so I could install it
